CRT throw
Discussion in 'Projectors, Screens & Video Processors' started by rigman, Feb 25, 2001.
  1. rigman
    rigman
    Dec 14, 2000
    2,964
    83
    East Yorkshire
    +112
    Does the distance between the projector lenses and the screen depend on the make of the CRT projector? Say if you had a ceiling mounted Sony or Seleco, then you wanted to change it to say a Barco, would you be able to mount it in the same place and get the same size image.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    It depends on the lenses being used in the units, rather than the manufacturer. So, you might have a Seleco 310 and want to upgrade to an 800. You'd probably have to move the projector bracket.....
    However, if you had a Seleco800 and you changed to a Runco933 you'd probably be alright as they both have HD145 lens assembly's
    Hope this helps,
    Gordon
    StereoStereo
    Intelligent Solutions for Intelligent Homes !
    [This message has been edited by Gordon, StereoStereo (edited 25-02-2001).]
  3. rigman
    rigman
    Dec 14, 2000
    2,964
    83
    East Yorkshire
    +112
    Thanks Gordon as usual you are a mine of information. By the way that was a nice job you did on the Schiehallion. I work offshore in the North sea and would not work on that place for all the tea in China. A bit too rough I prefer a fixed platform. Maybe I can persuade the powers on here to buy a similar system for us.
    Darren
    [This message has been edited by cossie0 (edited 25-02-2001).]
