Crt setup
Discussion in 'Projectors, Screens & Video Processors' started by darrenjames, Jun 14, 2005.
  1. darrenjames
    darrenjames
    Mar 2, 2004
    staffordshire
    I have recently purchased a Seleco 350 projector, huurrraaahh!!!
    However:
    1:- I have no idea how to set it up
    2:- I have no manual
    I was hoping to have the manual to give me some idea how to set it up. Could someone tell if the manual will give me the knowledge to set it up properly or will i need a professional? i currently have an lcd projector (panny pta200) and cant wait to see the difference between the two!
  2. crispybig
    crispybig
    Sep 28, 2004
    273
    +6
  3. Paul D
    Paul D
    Dec 27, 2000
    2,620
    Manchester
    +391
    Do a search for member "Chris Frost".
    He's your man for Seleco's, and is based in Cheshire... :smashin:
  4. Nebby
    Nebby
    Apr 6, 2004
    1,155
    Cambridgeshire
    +40
    Second the recommendation for Chris Frost :smashin:
    You should be able to search my posts and find a suitably glowing reference for the wonders he worked on my Seleco 320 Plus.
  5. darrenjames
    darrenjames
    Mar 2, 2004
    staffordshire
    Cheers all! Thanks for making me welcome.
    When i've got it all setup and running properly i am hoping to post a link to pictures from both "lcd" and "crt" projectors and show my home setup.
    Its good to become a member of the CRT club!
    I should receive my Seleco projector in the next few days, i will let you know how im getting on!
  6. chaz
    chaz
    Apr 7, 2003
    3,383
    87
    sussex
    +176
    IThird that chris Frost he is great at seting Seleco's up right :thumbsup: :smashin:
  7. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    Hi Darren, in a nutshell...
    You need to start by getting your 350 the correct distance away from the screen (1.5x the width of your screen), DEAD centre and exactly perpendicular to it.
    Then you need to focus all three tubes.
    Now get the red and blue tubes lined up mechanically onto the green (need a long Phillips screwdriver).
    Next you need to get the green tube's geometry set up PERFECTLY (using the little presets), and..
    Finally you need to line up the red and blue tubes over the green (which is why the green needs to be spot on!!) - again using the little presets in the correct order...
    There's a lot of trial and error - you will probably need to try it a few times.
    If you get in a real mess, CENTRE all the presets and start over...
    Good luck!
    Hope this points you in the right direction...
    Keith
  8. darrenjames
    darrenjames
    Mar 2, 2004
    staffordshire
    Thanks Keith,
    I should receive my projector today!!! if its not too warm tonight i will try and set it up following your guides. Sounds pretty straight forward but im sure it will take more than one night! Maybe i should get some cold beers in.
