Converting a Barco 1209 Data to a 1209s Graphics projector. From and with permission from MadMrH's
ONLY info taken from units I have here
list shows highest version of the boards found on the pcb print
D9s to G9s needs H,V, Scan and cpu change
8s/2 to 8s/E motherboard,EHT,splitter,quad BUT no advantage that I see as many more older eht/splitter/quads available
Would be nice to have details from a G1209s, Cine9 and 909
My units are 1998 at the newest
Details from a BG1209/2 from avs member are from SEOS unit and not complete
BOARD TYPE G1208/2 G1209/2 G1208s/2 G1208s/E 1209 D1209s latest version found G1209s Cine 9 909
(info from SEOS 1209/2)
Focus Horizontal shift board R762271 R762271 R762271 R762271 R762271 R762271 v6 R762271
seos for above board seos # 2012-0211
Horizontal output board R7621085v8 R7621085 R7621085v9 R7621085v10 R7621085v10 R76226715 v10 R7621085v10
Vertical Board R7621127v3 R7621127 R7621127v5 R7621127v5 R7621127v5 R769003v5 sub boards all the same R7621127v5
seos for above board seos 2012-0209
Port 3 R7621055v3 R7621055 R7621055v4 R7621055v4 R7621055v4 R7621055v4 v4 R7621055v4
RGB switcher R7617481 R7617481 R762719v1 R762719v1 R762719v1 R762719v1 v1 R762719v1
Quad decoder R7621175v5 R762700 R762720v1 R762720v1 R762720v1 R762720v1 v1 R762720v1
(CM board R7624845-02)
SMPS R762106v7 R762106 R762106v7 R762106v7 R7621065 R762106v7 main v7 sub board v12 R7621065
G2 R762120 R762120 R762120v9 R762120v10 R762120v10 R762120v10 v10 R762120v10
EHT Board R762457v3 R7617427 R762716v0 R7617427 R762716v0 ALL green or ALL R762716v0
Orange in any PJ
Quadrupler R761743 R761743 R762833 R761743 R762833 DO NOT MIX R762833
or big bang!
splitter R7617447 R7617447 R762718 R7617447 R762718 R762718
Motherboard R762101B R762758 R7627581 R76210118 R7627581
Scan R762457v3 High/Low R762457v3 High/Low R762457v7 High/Low R762457v7 High/Low R7621385 (low only) v7 R762457v7 High/Low
Controller R762166 R7625115v7 R7625115v8 R7625115v8 R7625115v7 v8 R7625115v8
firmware GR1208/2 5.31 GR1208s/2 7.03 GR1208s/2 7.14 D1209 7.14 v7.14 G1209
RWI 5.06 5.08 5.08 5.08 v5.08
ADEC G2.00 3.01 3.01 3.01 v3.01
INT not found on board 100 100 100 v100
Tubes 180 PT18-205 or P16LNQ PT18-205 or P16LNQ PT22 or P19LCP P19LUG P19LUG
Neck cards big black type R762746 v2 or v3 R762746 v3 or v4 R762839 v0 R762839 v0
NOTE 180 deg rotation
