CRT projector probs with R1 DVDs
Discussion in 'Projectors, Screens & Video Processors' started by stuart1, Jan 13, 2001.
  1. stuart1
    stuart1
    Can anyone help? I have a Region 1 Pioneer DVD player and a multiregion Pioneer portable. Whenever I try to view any of my Region 1 American DVDs through my video projector, a Vidikron CRT, the picture is b+w and rolls. I understand that this is because both players convert from NTSC to PAL 60 and not regular PAL 50. It may also have something to do with Macrovision. What can I do about this? I don't want to have to repalce equipment. Can I buy/make a simple conversion unit?
  2. charles
    charles
    Jul 6, 2001
    1,431
    63
    norwich
    +204
    Is your pioneer player really region 1 and not 2?..i thought a region 1 would output ntsc?...what are your connections?..is the vidikron multistandard?
  3. stuart1
    stuart1
    I have 2 Pioneers - a region 1 and a portable region 2 (multiregion). There is a selector on both to change between NTSC and PAL but this is PAL 60 not PAL50. I have tried RCA connectors, SCART connectors and BNC. Vidikron projector is PAL only.
  4. charles
    charles
    Jul 6, 2001
    1,431
    63
    norwich
    +204
    Your pioneer region 1 is outputing ntsc which the vidikron cant cope with..you need something to transcode the ntsc signal into pal.
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,615
    Somewhere in South Yorkshire
    +6,157
    From what you describe, it appears that your projector won't display the 525-line 60hz image that is intrinsic to NTSC video (and it's PAL60 cousin). What you seem to need is either
    a) a new projector capable of 525/60 display
    b) a DVD player which will output "true" PAL/625/50 (AFAIK, only certain Samsung models do this, and not too well - jerky movement)
    c) a video standards converter. Among other places, Lektropacks do several. Their "best" one, which is S-video compatible, costs £599.
    www.lektropacks.co.uk
  6. stuart1
    stuart1
    Thanks Charles. All rather pricey options though! I have heard that a PAL 60 to PAL50 convertor is available. That was from a DVD specialist but he did not know where to get one.
