Quantcast
CRT PJ Specs vs Screen Material
cosmic023
Hi All,
Well i'm after a formula to work out ft-lamberts of my setup, i've seen a few examples.
But then my BD801s is rated @ 900 ANSI lumens, which i know is a lot. (I'm sure it's much lower than that ??)
I know my screen gain is 1.0 and 72" x 54" in size.
How do i work out the ANSI - Ft Lamberts formula once i've worked out the corrected PJ ANSI output ??
Once i knew how to work out the formula, i could then do the formula with different gain screen materials.
Many Thanks
Cosmic023
cosmic023
Anyone ??
But I've seen on the AVS forum that even a Sony G90 pushes 1300 lumens and is only about 250 lumens corrected ??
I've seen a formula like this......
PJ lumens (Multiply by) screen gain (Divided by) Square Area of screen = Ft Lamberts
Just wondered if there was anyone out there that could help me with the formula ??
rob12770
Eh ?
I think 10 lambert & butler are about £2.10 or so but I have no idea how much a twenty pack costs, sorry.
cosmic023
Cheers Rob:
Yeah i found that link while searching for screen material retailers. (allready had the formula by then.)
But then i did a search (In the first place), and didn't find anything, seems to make a difference on the terms used for a search ??
Cosmic023
