Crt Mounting Idea
Discussion in 'Projectors, Screens & Video Processors' started by rob12770, Jan 2, 2005.
  1. rob12770
    rob12770
    Jan 5, 2004
    854
    Edinburgh/Glasgow
    +42
    i just got a digital camera so i thought id show you how i mounted my PJ,
    when i inspected my "joists" i found they were concrete and of no use (pj wise) so i came up with the idea of a shelf, of sorts,
    its been up there for a year now and no problems atall, still have to get trunking for the wires,
    as you can see its all about angle iron, 6 peices in all, bolted together, i used 17mm rawlbolts to attatch it to the wall, 4 of them for safety, (Very long and strong)
    and 6 standard 13mm nuts n bolts for the angle iron,
    the PJ just sits atop the bars, on square tubing bolted to the PJ ,
    i should really trim these but I am too lazy :D
    its a pretty easy job and for those who cannot use the ceiling , i think a pretty good souloution, its an old barco data 650, works great though,
    cheers rob :clap: , ( i love these Imoticons)
    any comments good or bad welcome.
  2. Parmenion
    Parmenion
    Feb 6, 2002
    1,260
    Out there
    +51
    Coming up invalid attachment (whatever that means !)
    regards
    Parmenion
  3. rob12770
    rob12770
    Jan 5, 2004
    854
    Edinburgh/Glasgow
    +42
    yeah it says pending..on the profile thingy.. any admins help ?
    really dont like the new site setup, all very confusing, cant find anything. :mad:
    ok so i somehow managed to get the pic up but if i try to edit the first post it dissapears, so il just leave it..pretty complicated way of attatching a pic :confused:
    but still the best forum around :hiya:
