crt leaking
Discussion in 'Projectors, Screens & Video Processors' started by denbo, Sep 20, 2005.
  1. denbo
    denbo
    Oct 31, 2004
    Hi i have a crt that leaks a little from the top seal can you get a new one or not.is there a way of resealing it thanks.
  2. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    522
    North Cotswolds
    +3
    You can try silicone sealant (like you use for the bath) but tbh I couldn't get mine to ever re-seal :(
  3. denbo
    denbo
    Oct 31, 2004
    Okay i will give it a try as its only 18 months old.Thanks for your reply.
