CRT Electrohome marquee 8500 - boards
Discussion in 'Projectors, Screens & Video Processors' started by thxbest, Jul 16, 2004.
  1. thxbest
    thxbest
    Jul 16, 2004
    14
    Hello,
    have a question on a Marquee 8500
    The Marquee is from 1996. Would I like to know. Does the Marquee 8500 have these boards into this?
    1- Stigmator Waveform Board
    2- Stigmator Board
    3- Focus Coils
    4- Color Correction Boards
    The Marquees Ultra 8500/9500LC have these boards. What is this like at older Marquees 8500?
  2. thxbest
    thxbest
    Jul 16, 2004
    14
    Hello,
    does it know nobody? :confused:
  3. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    You'll probably get a better response from the US based AVS forum where there is a lot more 'activity' with respect to Marquee projectors. I suspect that there are similar boards between these models but you'll need to know the board numbers to find out if any are interchangeable.
    Brian.
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    THXBEST
    I'm fairly certain your projector will have all 4 boards. E'Homes were not that popular in the UK so the level of support was weak.
  5. michaelka
    michaelka
    HI THXbest,
    it depends on what options are included in your Marquee.
    Normally all these boards are included.
    The stigmator waveform board is located on the systemboard (RS232 Conectors) just plug it out, than you will normally see a big board this is the Systemboard.
    On this systemboard are two other boards, one is DPB (deflection Processor board) and the other should be the stigmator waveform board.
    The stigmator amplifier board is located in the back of the projector (next to convergence and vertical deflection board).
    Focus Coils ?? every Marquee has the Focusboard!
    And what do you mean with colour correction? If you want to change the colour temperature you can do it via the Service Menue!
    If I can help just let me know!
    my email : [email protected]
    I'm from Germany so my english is not the best :)
  6. michaelka
    michaelka
