CRT desk mount?
Discussion in 'Projectors, Screens & Video Processors' started by (GTV)Chris, Jan 9, 2003.
Thread Status:
Not open for further replies.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Is there a way to hide a CRT projector at Coffee table level.
    I want a second hand CRT and I am having a battle with my wife about putting something the size of a Mini on the cieling.
    Is there a housing available for a floor standing version?
    My room is approx 14ft x 10ft and I already have a 7ft screen.
    Bearing in mind that there will be a sofa etc in the room do you think I should just stick with my Panasonic PTAE100?
    Thanks for any advice.
    Chris
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    why dont you download pjcalc and see if you can actually fit one in your room, i have a room that is about 14x12 and have had to scrap the sofa for a recliner either side of my crt.
  3. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    Ikea used to sell loads of coffee tables, I had my NEC on one for about 6 months, worked fine and was hardley noticeable.
Thread Status:
