CRT cost
Discussion in 'Projectors, Screens & Video Processors' started by clancol, Sep 9, 2003.
  1. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    Ok guys. Tell me, what is the cheepest price that i could get a decent crt projecter thats better than most lcd's? Where could i get it? what size room would i need? what connections would i need? and what about Pro scan.
    Come on guys Knock yourselfs out.
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Hmmm...over two hours of silence.
    Perhaps they all did ;)
    Have you checked the forum classifieds?
  3. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,668
    Newbury
    +215
    well, i have a barco 801s that i paid a grand for. the image it produces is just like a TV image only much larger. its sharp enough to be a digital photograph projector too. yes you need a line doubler too for video sources, i have an iscan pro which i got for £500. and you shouldnt skimp on the screen.. my 7ft 16:9 1.2 was about £500.
    a CRT PJ isnt small. mine is just short of a metre in length and 40 cms tall. a decent coffee table will cover it for a floor install. minimum throw distance for a 7ft screen is about 10 feet or so from the front of the PJ. so you can see how large your room needs to be.
    i dont think any LCD is worth buying for home cinema unless you have a room that just cannot accomodate a CRT PJ. LCDs just dont do black or have anything like TV quality images.
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    £500 to £100 should be pretty easy.
    I couldn't possibly tell you where to get one.;)
    but I'm sure Chris could
  5. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,668
    Newbury
    +215
    :D
  6. meep
    meep
    Apr 22, 2002
    728
    Ireland
    +93
    Check out my website linked in my sig.
    Lots of stuff there.
    Also, try going back over time in this forum. The CRT forum is not that busy and these newbie questions come up every so often.
    Peter
