CRT better than LCD??
Discussion in 'Projectors, Screens & Video Processors' started by scott33b, Aug 3, 2004.
  1. scott33b
    scott33b
    Aug 3, 2004
    68
    Hi. I have a Sharp XG3785E Lcd projector. Its about 6years old. Iam considering buying a second hand CRT poss. a Barco 801s. Is this crt better than lcd? Are the colours more vivid, brighter, etc.? Thanks
  2. secstate
    secstate
    Jul 30, 2004
    United States
    This is a loaded question. I believe just about any CRT projector will be better in most respects than a 6 year old LCD display. That was at the dawn of fixed pixel (digital if you insist) projectors.
    Pros for CRTs:
    Generally better picture for the price
    Good colors and resolution
    High end CRTs 8" and 9" EM focused projector as still better than best digital rivals.
    Meant to be and can be repaired, spares still widely available for popular models though this varies somewhat from area to area (e.g. Electrohome, Barco and NEC are widely available in the States, Electrohome parts are much less widely avaialble in Europe).
    Cons for CRTs
    Relatively complex to set up (not rocket science either, well unless you are talking the mechanical white balance on NECs)
    Heavy and large
    Getting older by the day and thus part failures may become more common
    Pros for Fixed Pixel Projectors (LCD/DLP)
    Generally come with built in scalers (extra cost with projectors)
    Easy to set up
    Brighter (though the difference is less than advertised)
    Light weight
    Come with a warranty
    Cons for Fixed Pixel Projectors (LCD/DLP)
    Disposable
    Bulbs can be hard to get for older models
    Cost, the better quality fixed pixels cost dollars
    Artifacts (poor blacks, DLP rainbows, screen door effect, etc...)
  3. scott33b
    scott33b
    Aug 3, 2004
    68
    Thanks for the reply. I think I'll be changing to a crt. The lamp in the lcd is getting past it. Considering buying used on e-bay.
  4. secstate
    secstate
    Jul 30, 2004
    United States
    You can do ok on Ebay but make sure you are comfortable doing repairs yourself and/or have access to somebody who can do them. One of my Barco 808s was from Ebay the other was U.S. Government surplus. The one I got from Ebay had great tubes, decent price, but need a repair to one of the boards. Also educate yourself as much as possible on the model you are interested in as Ebay sellers seem to mis-list things all the time. A Barco 808 Data become and Barco 808s Graphics and so on.
  5. rob12770
    rob12770
    Jan 5, 2004
    854
    Edinburgh/Glasgow
    +42
    yes crt are much better , big and bulky, but if its picture quality you need then yes go for it ! :thumbsup:
  6. rob12770
    rob12770
    Jan 5, 2004
    854
    Edinburgh/Glasgow
    +42
    you dont have to spend much , i got an old barco data 650 crt for £250 and it beats both the lcd and dlps i had before, so dont worry about getting high end stuff,, get a cheap one, see if you like it THEN get a dearer one later..(if you want)..im just keeping the 650 until its dying days..which seem far off in the distant future. 12 years old and it works like a charm,
    just my thoughts on the subject.
  7. scott33b
    scott33b
    Aug 3, 2004
    68
    Hi. Thanks for all the advice. Just Taken delivery of a Barco data 801s. I bought it on e-bay for £400. Its in excellent condition with low hours on the lamps. I didn't think it would be as big though!
    My next problem will be connecting it and setting it up!
  8. rob12770
    rob12770
    Jan 5, 2004
    854
    Edinburgh/Glasgow
    +42
    sounds good scott, yes they are massive, and at first it will be a pain to set up, but once you get used to it you will find that its very worth the extra effort. :thumbsup:
  9. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    One more of us one less of them
  10. cinesom
    cinesom
    Aug 30, 2004
    30
    I have been a CRT fan for years (installing and selling), my own demo room still has a Runco 944 (Barco chassis), but over the last couple of years clients have been wanting a more flexible (i.e. multimedia) and smaller solution. Our most recent project included installing Runco's new VX1000ci DLP. These have been precalibrated in PAL and NTSC by ISF, WOW! Amazing depth, clarity. Using the correct screen material helps- Runco reccommends the Stewart Firehawk - wham bam thank you mam! Definatly a large step forward in DLP technology and image processing, but a bit pricey!
  11. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I have to leap in here before Gordon but how is it possible to do an effective calibration with out all the signal equipment, cables, screen and decor in place?
    All of these will affect the final image when it is installed in situ.
    All DVD player output different levels and colour balance
    All cables will have differing impedence and characteristics that will affect the signal levlel.
    Screen materials vary in colour and the amout of light they will reflect from thier suroundings
    The colour of the room will reflect onto the screen and will alter the colour balance very significantly.
    It would be like performing an amplifier set up before delivery to the customer.
  12. Lux In Umbra
    Lux In Umbra
    Aren't the cable impedence & the colour balance issues reduced (eliminated?) using digital connections {for DLP here, remember, rather than the real deal (CRT, of course)}? (Not going to wade in on the other stuff - screen, etc, though!)
  13. cinesom
    cinesom
    Aug 30, 2004
    30
    Roland,
    A very fair point you make. What I really meant was the performance "out of the box" that was stunning.Stewart Screen was in place, decor, acoustics, cables and hardware had already been taken care of. Having been stunned by its out the box performance, we then did further calibration, but very minor to get it fully up to speed. It was twinned with Linn's Unidisk 2.1 DVD, Kisto processor, Akurate package. Unidisk has superb definition, so I supose that helps in out of the box performance.
