Crown 32" @ Woolworths - £599!
Discussion in 'LCD & LED LCD TVs' started by DaveP, Aug 24, 2005.
  1. DaveP
    DaveP
    Woolworths are doing this for £599. I have not been able to find out much information other than that it has PC input and a res of 1366x768. Even the Crown site has very little info.
    Dave
  2. bignige
    bignige
    May 13, 2003
    666
    +27
    If the picture is anything to go by, it's exactly the same as the ASDA Dual 26" which has a Hitachi screen.
    I've got the 26" Dual & it's great, am tempted to return if this is bigger, but the same build quality & screen.
    Further info is needed!!
    **Edit** I've emailed Crown, requesting Tech Specs. If they get back to me. I'll post them up.
  3. briancowings@ho
    briancowings@ho
    Feb 27, 2005
    47
    +3
  4. bignige
    bignige
    May 13, 2003
    666
    +27
  5. Bilbob
    Bilbob
    Feb 21, 2005
    4,534
    103
    Manchester
    +292
    If anyone is seriously wishing to buy this set, PM me, and I'll send a link to give %10 off...
    I don't want to post it publicly, as I don't wish the offer to be withdrawn, so please don't abuse it! If you are seriously considering it, then I'll provide the link!
  6. Kong
    Kong
    Aug 20, 2005
    360
    i would be interested in this if it has DVI with HDCP or HDMI connections, does anybody know if it does?
  7. DaveP
    DaveP
    There is one for sale on eBay with loads of pictures but none showing the inputs.
    It's identical to the Dual/Hitachi 26" right down to the remote control, just bigger!
    Dave
  8. bignige
    bignige
    May 13, 2003
    666
    +27
    Actually, the remote is different. It has buttons for volume etc. The Dual has a circle split in to quarters.
  9. DaveP
    DaveP
    Actually, there is a picture of the supplied remote on the eBay page which differs from the remote pictured on the Crown site. I maybe wrong though. I have so many bl**ding remotes!
  10. bignige
    bignige
    May 13, 2003
    666
    +27
    tell me about it. I have a whole draw full of them, yet can never find the one that's needed!!
  11. bignige
    bignige
    May 13, 2003
    666
    +27
    If we assume this is based on the Hitachi 32LD6200 (the 26" Dual is based on the 26LD6200) a link for the specs is here.
    http://www.hitachidigitalmedia.com/DMG/viewProduct_1.jsp?productid=432&drilldown=7&urlnumber=0
    One thing that stands out (maybe a typo) response Time 25ms?!!! Isn't that crap?
    Please note, it's only guess work that this is based on the Hitachi, although the fact it looks identical and previous styled smaller models were rebadged Hitachi makes me pretty certain it is.
    Bilbob, you have a pm. Cheers mate.
  12. coley65
    coley65
    May 27, 2005
    152
    +4
    Looks nothing like the Hitachi to me
    Coley
  13. bignige
    bignige
    May 13, 2003
    666
    +27
    Are you blind? The screen surround is identical minus the badge & front bump. The stand is different, same as the Dual. The back and side are the same also.
  14. coley65
    coley65
    May 27, 2005
    152
    +4
    Hmm let me have a second look nope still nothing like it to me. Sorry I must be blind then.
  15. coley65
    coley65
    May 27, 2005
    152
    +4
    do see what you mean after a closer look
  16. DaveP
    DaveP
    It (the 32ld6200) has the same inputs as the 26" version so includes DVI and VGA.
  17. bignige
    bignige
    May 13, 2003
    666
    +27
    I've just been in to Woolworths and had a look at the manual, firstly (slightly dubious) it says it has a response of typically 8ms.
    The bad news is, it has no DVI of any sorts, just VGA.
    They were running Lilo & Stitch on the actual TV, the picure looked pretty good & very similar to the Dual.
    Shame about the lack of DVI.
  18. DaveP
    DaveP
    That is bad news! And no component either?
  19. owen_uk
    owen_uk
    Thinking about getting one - doe's anybody know what/if there's a code for Sky remote?
    www.satcure.co.uk/tech/digicode.htm Lists some Crown codes but I don't know how old or relevant they are.
    The Crown Website is useless for information so I phoned them and they weren't much better, I did find out it has 2 Scarts, Composite, SVHS and DSUB inputs.
    Thanks for any help.
  20. bignige
    bignige
    May 13, 2003
    666
    +27
    No component either. I can't believe the lack of DVI. There's just nothing in place of it (except a large chunk of plastic!)
    Owen, I wouldn't bother with it.
  21. coley65
    coley65
    May 27, 2005
    152
    +4
  22. ButtonUPS
    ButtonUPS
    Jan 9, 2005
    270
    Haywards Heath
    I am also interested in this setup for my xbox hd via x2vga cable setup. i will have a look at my local branch see if i can get some details.
    ps obviously these are rgb scarts? :rolleyes: :lease:
  23. owen_uk
    owen_uk
    It's not for me - it's for my parents, it'll do just what they need it too; just a DVD, VCR and a Digibox so no need of Components, DVI or even a DSUB.
    Knowing the Sky remote code would be great though, It'd just be easier for them not to have to switch between two remotes - I don't think they've even got the hang of one yet!
    As for the SCART's being RGB... hmmm well give them a call (0871 220 4600) good luck on that one.
  24. owen_uk
    owen_uk
    Just looking around and I see that the Crown CTT3207W bears a striking similarity to the Goodmans LD3202 – are they the same TV? who actually makes them?
    [​IMG]
    [​IMG]
    The Goodmans spec says 2 RGB SCARTs so I guess the same for the Crown.
  25. Caprylate
    Caprylate
    Aug 1, 2005
    84
    +3
  26. ButtonUPS
    ButtonUPS
    Jan 9, 2005
    270
    Haywards Heath
    looked at the manual today definetley no dvi............but do i need one is there A HELL of a diference between vga d sub and dvi at this resolution anywho? :cool:
  27. ButtonUPS
    ButtonUPS
    Jan 9, 2005
    270
    Haywards Heath
    can guarantee 2 rgbs may buy one tomorrow
    :thumbsup:
  28. Paulando
    Paulando
    Apr 24, 2003
    272
    Manchester
    +18
    I've been looking for an LCD with a DVI/HDMI connection and a couple of Component inputs, but I'm wondering if I'll need all of those and a VGA might just be enough, really.
    I won't be using Sky HD, or watching normal TV through it. It'll be mainly used for watching DVDs and playing the current and next gen consoles. Would a Component > VGA converter and a Component splitter suffice for what I need? If so, I might just go for this one- £550 ain't a bad price at all :confused:
  29. ButtonUPS
    ButtonUPS
    Jan 9, 2005
    270
    Haywards Heath
    same hear dude i will run vga at maching res thru my laptop and hope for the best with my xbox
    :thumbsup:
    OH IT COMES WITH A VGA CABLE!!!!!!!! WHOOOOO :thumbsup:
  30. jtorry
    jtorry
    Nov 8, 2001
    520
    does this set have support for 480p. 720p and 1080i through the VGA port?
