Crown 32" LCD £554.98 inc del
Discussion in 'Shopping, Deals, Discounts & Bargains' started by coolio, Aug 28, 2005.
  1. coolio
    coolio
    Dec 31, 2003
    217
    +4
    Woolworths have a Crown 32 inch LCD with stand and wall mount for £554.98 including delivery online. Not sure how good it is but is about the same price as the makro one so may be of use to someone. You need go through the link below as it gets the TV for the reduced rate
    www.woolworths.co.uk/wanadoo
    Click 'Electricals' and it is just over halfway down.
  2. stuthemong
    stuthemong
    Dec 31, 2002
    457
    +6
    not a bad find at all
    http://www.empiredirect.co.uk/conte...?modelcode=CRW-CTT3207W&affiliateid=76&bhcp=1
    says it has a native res of 1366x768, so although its higher res than the one off ebuyer, its not a native HD.
    I think ill get the one from ebuyer becasue at 1280x720 its identical res as my projector, so ill have it setup on the PC output through a split VGA box - that way theyll both run native and will compliment eachother :D.
  3. ra11
    ra11
    Aug 14, 2005
    167
    16
    London
    has the Crown got VGA / DVI inputs? I dont think it has the DVI one, but VGA?
    If it has, am going to get one :eek:) - can someone please let me know asap?
    Thanks.
  4. chalkdust
    chalkdust
    Jul 8, 2003
    727
    +20
    Can only see a 27inch model?
