Crossover to Patch cable
Discussion in 'Desktop & Laptop Computers Forum' started by Urotsukidoji, Jul 12, 2004.
  1. Urotsukidoji
    Urotsukidoji
    Feb 20, 2003
    262
    19
    Greenwich, London
    I made a mistake and purchased 30m of CROSSOVER network cable instead of a PATCH network cable.
    I have searched the net and have found lots of patch to crossover adapters but no crossover to patch adapters.
    Is there any easy way to use the crossover cable as a patch cable?
    Cheers. :beer:
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    You could cut one end off and reterminate it.
  3. Urotsukidoji
    Urotsukidoji
    Feb 20, 2003
    262
    19
    Greenwich, London
    Is this hard to do? Looking at the end, it looks kind of tricky....
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Its not hard but there is a knack and you'll need a rj45 crimping tool.
  5. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
    Yeah, it's pretty easy to do, but the tool will be more expensive than an adapter if you're never going to need it again.
    Correct me if I'm wrong here cable guys, but isn't a crossover adapter going to work in this case? The adapter flips over a pair of wires, which should reverse the crossover wiring of your cables.
  6. Urotsukidoji
    Urotsukidoji
    Feb 20, 2003
    262
    19
    Greenwich, London
    Yes, I think it's all you need to hook up TWO computers, but I forgot about my xbox.
    So, I have two workstations, an xbox, and loads of crossover cable. Can I just buy another NIC and connect all three together, without a hub?
  7. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
  8. The Dude
    The Dude
    May 21, 2004
    6,270
    Beverley, East Yorkshire
    +2,594
    if you want all 3 connected together easily you'll need a hub/switch, as running two network cards in 1 PC can get tricky sometimes.
    Your crossover cable isn't going to be much use as it stands..
    As yandros says with regards to the adapters they're one and the same...
    ( or should i say there is only one kind :) )
    if you've got a crossover cable the adapter will turn it into a straight cable, and vice-versa..
    All it does it flips pins 1,2, with 3,6 thereby creating the opposite of whatever cable you plug in..
  9. Urotsukidoji
    Urotsukidoji
    Feb 20, 2003
    262
    19
    Greenwich, London
    Thanks all (esp. dude and yandros), I will buy an adapter and a hub, cheers again!
  10. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
    If you get that hub (actually its a switch to be precise), you don't need an adapter. The ports on the hub autodetect the cable type (cross or patch) and adjust accordingly. We use a 24port gigabit Neatgear swtich at work with that feature, and its really handy.
  11. Urotsukidoji
    Urotsukidoji
    Feb 20, 2003
    262
    19
    Greenwich, London
    Cheers again, ordered from ebuyer and saved a fiver!:)
