Crossover settings
Discussion in 'AV Receivers & Amplifiers' started by MS-Yam, Oct 28, 2004.
  1. MS-Yam
    MS-Yam
    Aug 12, 2004
    240
    16
    I would like to know the best crossover settings for my amp and sub if anyone can help. Here's my equipment:
    Yamaha 640SE amp
    Mordaunt-Short Avant 906 fronts, 905c and 902 rears
    MS 308 sub.
    As they are full range speakers, they take care of some of the low frequencies. Does this mean I should set my sub at a fairly low crossover point?
    Also, there is a phase switch on the sub which can be set to either 0 or 180 - which will be the better option?
    Any help would be great, thanks
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,154
    2
    +3,588
    I have 914,905 & 506 with an MS909 and still set at 80hz for films- I just prefer it that way. You could try a 50hz crossover though which would clip the bottom off the 906's but would be the limit for the centre and rears.
    Ed
  3. MS-Yam
    MS-Yam
    Aug 12, 2004
    240
    16
    Thanks for that, would this setting be on the amp or sub?
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,154
    2
    +3,588
    Mine is on the amp- I prefer to set it there and then just max the sub crossover.
  5. MS-Yam
    MS-Yam
    Aug 12, 2004
    240
    16
    Cheers for that, i'll give it a go.
