Ive just bought the KEF 2005.2 sub and sat, what do i set the crossover point on sub too. Ive read instructions but its still double dutch. please help
I disagree with Dean. If there is a switch on the sub to switch the internal crossover out you should use that instead. If there isn't a switch then set the crossover as high as possible and let the crossover in the AV amp handle all the bass management.
I agree with Ian, you should leave your AV Receiver to deal with the crossover which you should set to 80Hz. You then just turn the crossover on the subwoofer to its maximum setting.
