tim1982
Established Member
Evening all, I've been having a tinker tonight with my 5.1.2 set up and have found that in certain "bassy" moments in movies my height speakers are giving off to much bass and are shaking the wall. If I was to change the Hz crossover so the sub took the strain off the speakers would I need to lower of higher the Hz crossover on my receiver?
At present my set up is as follows:
Fronts: 90hz
Centre: 90hz
Height:120hz
Surround:120hz
Sub: 120hz
The recommended range for the heights is between 120hz-22,000hz so I'm assuming if I go down to 100hz it could damage the speakers??
Fairly new to this stuff so please be kind!
Fronts: 90hz
Centre: 90hz
Height:120hz
Surround:120hz
Sub: 120hz
