Crossover Frequency?
Discussion in 'Subwoofers' started by bravogolf, Jan 24, 2008.
  1. bravogolf
    bravogolf
    Mar 24, 2006
    1,296
    +123
    Hey chaps. I have the Canton 102 5.1 set and on the Subwoofer there is an independent crossover control. I've no idea what this should be set to! Any recommendations is much appreciated! As far as I can tell, you're telling the sub when to take bass from the speakers?
  2. Dave964
    Dave964
    Nov 14, 2007
    1,548
    Camberley
    +260
    Typically, 80Hz is the starting point - and yes, your understanding is correct.
  3. mjcairney
    mjcairney
    Oct 26, 2003
    7,275
    2
    137
    Airdrie, Scotland
    +1,074
    I don't know any specifics for your set-up, but a general rule of thumb is 80Hz.
    Cheers,
    Martin.
  4. bravogolf
    bravogolf
    Mar 24, 2006
    1,296
    +123
    Thanks guys, interesting to know. My last system didn't even have a crossover yet it seems very important for good sound management.
    According to the website, my speakers are:
    Front: 80...25.000 Hz
    Center: 80...25.000 Hz
    Surround: 80...25.000 Hz
    Subwoofer: 33...140 Hz
    So settings to 80Hz is still oK?
  5. Dave964
    Dave964
    Nov 14, 2007
    1,548
    Camberley
    +260
    If you use 80Hz as a starting point you can always adjust from there and see if it's better.
    I'm surprised your speakers say the min. is 80Hz - I think I checked mine when I got the sub and it was some wildly optimistic value like 45Hz, but the SPL meter proves that this might not be entirely true.
  6. ben.bayliss
    ben.bayliss
    Feb 4, 2007
    1,198
    63
    +136
    I'd be tempted to start a bit higher than that as those satellites aren't very big.
    As always, close your eyes and use your ears.
  7. Dave964
    Dave964
    Nov 14, 2007
    1,548
    Camberley
    +260
    Ah, hence the 80Hz (I should have followed the link).
    I agree - you'll probably end up higher than 80Hz, but it's a good place to increase from.
  8. bravogolf
    bravogolf
    Mar 24, 2006
    1,296
    +123
    Ok, cheers. And, just to be sure, higher being an increase from 80Hz to say 90hz, or is it the opposite way round? Am not sure if higher bass == lower Hz!
  9. Dave964
    Dave964
    Nov 14, 2007
    1,548
    Camberley
    +260
    Higher = 90Hz.
  10. sdb123
    sdb123
    May 17, 2005
    18,181
    2
    Rushden, Northants
    +2,252
    Can the crossover frequency be turned off or bypassed on the sub? I would manage the crossover frequency for all your speakers via the Onkyo amp that you have.
  11. bravogolf
    bravogolf
    Mar 24, 2006
    1,296
    +123
    Thanks all.
    sdb123 - I'll check the manual this evening, cheers.
  12. Dave964
    Dave964
    Nov 14, 2007
    1,548
    Camberley
    +260
    If you can't turn it off, you could just set it to max - my amp manual suggests this, although I've ignored it and used the crossover frequency on the sub.
