Crossover frequencies Pio VSX-2014i-S
Discussion in 'AV Receivers & Amplifiers' started by Mathias, May 9, 2005.
  1. Mathias
    Mathias
    I plan to buy the Pio VSX-2014i-S to I-link with my DV-868.
    For the speakers I have decided to install the very nice looking but also wonderful sounding Cabasse IO satellites in a 7.1 setup.
    But the speakers just go down to 180hz.
    What are the different crossover frequencies who can be set up with the Pio ?
    The online manual gives no info.
    Thank you for your help
  2. Gixer750
    Gixer750
    Just got one of these amps at the weekend, but I think it lets you select the Crossover level from 50hz, 80hz, 150, & 200hz...
    Would have to double-check though.
  3. Mathias
    Mathias
    I hope you will be happy with your new Pio.
    I also considered the KEF KHT5005 set but went for the Cabasse after audition.
    Could you please double-check for the crossover and let me know?
    Thanks and best regards
  4. Gixer750
    Gixer750
    Mathias,
    I have double-checked the amp and the crossover can be selected from (50hz, 80hz (THX), 100hz, 150hz, 200hz)
    So it looks like you will be able to select the 200hz Crossover and enjoy you speakers.
    Hope this helps
