Question Crossover confusion
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by jorjov, May 22, 2019.
  1. jorjov
    jorjov
    Nov 5, 2017
    14
    4
    Norway
    +4
    Hi all!
    I have a Marantz SR8012 that I struggle a bit with.
    I have ran Audyssey.
    All speakers set to small. Also in 2 Channel Playback
    Crossover set to 100Hz on all speakers. Also in 2 Channel Playback.
    SW Mode is set to LFE.
    2 subwoofers (B&W ASW610XP)
    Sound mode is Music/Stereo (no direct or pure direct)
    Audyssey is set to reference.
    When I play test tones from 40Hz to 150Hz both the subwoofers and main (front) speakers are outputting sound. I can feel the woofers moving on my front speakers all the way from 40-50Hz and up. I also get sound out of the sub from 100Hz and up. What is causing this behaviour? I have played test tones from multiple sources with the same result. It's like the crossover is not in play at all.
    Best regards
    Jorn
  2. jamieu
    jamieu
    Jul 3, 2010
    183
    London
    +64
    Maybe I am misreading the question, but a crossover doesn't just cut off below & above a given frequency, it's more of a slope. So you'd expect to hear some >100Hz content from your sub and some <100Hz content from your mains.
  3. jorjov
    jorjov
    Nov 5, 2017
    14
    4
    Norway
    +4
    Thanks for the reply jamieu :)
    I know there can occur some bleeding. But I didn't expect the main speakers to play fairly load at 40-50 Hz. I would expect a roll-off at around maybe 80-90 Hz.
    Having said that I tried turning off the subs, and only played using the 2 front speakers (B&W CM10 S2). The sound was quite a lot fuller at Direct/Pure Direct than ordinary stereo. So I guess there is a cutoff, but I expected it to be more pronounced.
  4. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,060
    Zurich, CH
    +1,548
    The THX crossover definition is:
    The reason for the differentiation between the LCR and the subwoofer is the THX rolloff specification for the LCR speakers of -12dB/octave, summing to -24dB/octave effective. For this to work at the 80 crossover frequency, signals must be -3dB for both LCR and subwoofer at crossover (sum is then 0dB = flat).
    Most AVR's follow the THX definitions, but rather than fixing the filters, adjust the LPF / HPF during the setup to obtain a -24dB/octave total.
    We can now plug in the above numbers in your case of a 100Hz crossover: At 100Hz you need -3dB in both LCR and subwoofer. At 50Hz (one octave) you therefore have -27dB effective on the LCR, the same as the subwoofer at 200Hz (one octave). At 25Hz (LCR) you have -51dB, same as subwoofer at 400Hz. This is not very loud, but if you're looking for it, you'll find it.
  5. jorjov
    jorjov
    Nov 5, 2017
    14
    4
    Norway
    +4
    Well, I definitely found it. By chance really, when I was EQ'ing the subs. Anyway, thanks a lot for the clarification Mark. Much appreciated :)
