Crossover and setup question?
Discussion in 'Home Cinema Speakers' started by danfrance110, Sep 14, 2004.
  1. danfrance110
    danfrance110
    Hi All,
    Currently running B&W 602s3 and LCR60 up front and three gallo nucleus micro's at the rear, with a b&w asw600 sub. I have all speakers set to small on the amp (yamaha 640rds). How can I tell what the crossover is set at and what should it be set at for the best results bearing in mind the front speakers are full range and the rears are sats.
    Any help would be appreciated
    Dan
  2. BrianC
    BrianC
    Jan 20, 2003
    2,199
    +101
    I have a Yamaha 630 RDS (which is basicly the same amp) and you cannot set the sub/speaker cross over point with it as it is fixed at 80Hz.
