Crossover Advice
Discussion in 'Home Cinema Speakers' started by philthyanimal, Nov 13, 2003.
  1. philthyanimal
    philthyanimal
    any help welcome.
    My speakers only go as low as 120hz, what crossover level should i set on the amp? 100hz or 150hz.:confused:
    Also anyone know what Phase does on a sub?
    thanks
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    What is the sub setting on your amp? My crossover is set to max on the sub. The amp dictates what frequency is sent to it.
  3. philthyanimal
    philthyanimal
    i've set it to full on the sub. the amp offers 50, 80, 100, 150, 200hz cross over, but which should i choose? it says 80hz for THX speakers.
    Tha amp is an ax3 and the speakers are kef 1005s
  4. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    80 sounds like a good setting to me. With all speakers set to small.
  5. philthyanimal
    philthyanimal
    but if my speakers only go as low as 120hz, won't i loose the bass betwwen 80 & 120hz.
    My speakers are set to small for front and back
  6. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    In that instance I would choose 150Hz.
  7. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    What's the point in setting an 80Hz crossover if his speakers only go down to 120Hz. If there's really no usable output below this, then it really needs to be set at 150 (assuming the sub will go up to 150Hz).
    The downside is that you may be able to hear that the bass is coming from the sub, in which case, you may be better off going for 100Hz and putting up with a 'hole' in the frequency range.
    Try 'em both. Keep whatever sounds best.
  8. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Bloody hell, things move fast round here. My reply became irrelevant in the space of 3 minutes.
  9. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Was that aimed at me? Sorry if I didn't rush and check his speakers tech spec. :rolleyes:
  10. philthyanimal
    philthyanimal
    thanks to all for the replies.
    What does Phase do? and how should that be set
  11. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Have a play and see which sounds best. I personally have not used mine.
  12. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    I suppose it was aimed at you, but not in a way that you should have taken offence at.
    Seeing as you have though, I wasn't expecting you to check his speaker specs, just to have read the original post.
    :rolleyes:
  13. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    A phase control is designed to compensate for tthe fact that the bass is not coming from the speakers, but from another location in the room (your sub). Depending on the subs position in the room, it may sound better with the phase set to 0 or to 180.
    As suggested, use whichever sounds best, and if you can't tell the difference, don't worry about it.
  14. philthyanimal
    philthyanimal
    thanks,
    i'm about to move my sub to the other side of the room, so this might come in handy now i know what its for.
  15. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Take offence, never mate. ;) Not for something like that.
    As for not paying attention/miss reading the original question, guilty as charged.:blush:
    Gave the right answer in the end though.;)
