cross hatch pattern?
Discussion in 'Projectors, Screens & Video Processors' started by Roland @ B4, May 1, 2001.
  1. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Hi Chrisyt
    The shape of the boxes is probably not relevant. The fact that they are the same size is more important. Particlulary top to bottom. ie vertical linearity.
    Internal paterns from projectors are not brilliantly accurate and there for a guide more than any thing.
    Always best to use a source if you can. Draw a simple x hatch in paint if nothing else with an anmorphic circle to give you the 16x9.
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I've just remembered have a look at www.displaymate.com. there are a few down loads that will help. ;)
  3. chris thomas
    chris thomas
    Could anyone please tell me, when setting up a crt projector for convergence in the 16x9 mode should the cross hatch pattern boxes be square or rectangular has mine are rectangular and my mates are square.
    I,m using a pc dxr3 card which in the pcdvd programe is set to wide screen and my mates stand alone dvd is also set to output widescreen, but i get rectangular boxes in the cross hatch and his are square, both pictures seem to be fine but is this correct.? Any help please. both projectors are seleco svp 310 and svp 320. :confused:
