Needs some guidance on crossover settings for front speakers and sub.
If the fronts for example are set to 120hz, it will play anything above that, but below that I assume will all be sent to the sub?
And If the sub LPF for LFE is set to 120hz it will play anything below 120hz sent from the fronts and lower?
But if the Fronts was set at 150hz and sub LPF for LFE at 120hz there would be a gap or void in frequency between sub and speakers, So is it best to have an overlap between both?
