croma bug on arcam dv88+
Discussion in 'Blu-ray & DVD Players & Recorders' started by camlogan, Jan 28, 2003.
Tags:
  1. camlogan
    camlogan
    hi there all, does anyone know if the arcam dv88+ with the latest software has the croma bug?
    thanks
    CaM
  2. NicolasB
    NicolasB
    Oct 3, 2002
    5,885
    Emily's Shop
    +567
    Yes, and it can't be fixed by a software upgrade.
  3. camlogan
    camlogan
    hi there, thanks for the bad news :cool:
    CaM
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
  5. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    And does anyone really care ? Maybe I am not using a big enough screen yet for it to pose a problem.. but I still reckon that if that web article that started it all had never been posted would anyone really notice ?
    Personally I think you should be watching the movies not analysing the picture :)
    my 2p.
    Matt
  6. tipicus
    tipicus
    I've purposely avoided all articles describing what the bug looks like so I haven't got a clue what I'd be looking for. And I'm keeping it that way!
  7. juboy
    juboy
    Yes, it uses the same processor (Zoran Vaddis V) as the latest higher spec Toshiba models. Although Zoran had promised Toshiba that the 5th generation Vaddis wouldn't have the chroma bug, it still does.
    Apparently the effects of it have been masked well and the Vaddis V does a good job of 'pretending' it doesn't have the chroma bug but it is definitely still there.
    I'm not sure why a £1000 machine is using this cheap, multi-purpose chipset.
  8. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    The chroma bug looks bad on a 72" screen. Avoid it if you can.
  9. camlogan
    camlogan
    thanks for the info everyone.
    So what is a better chip than the Zoran Vaddis V then? Or maybe more to the point - what should the arcam have used?
    CaM
  10. juboy
    juboy
    Genesis FLI2200
    SiI504
    Having said that, the Vaddid V is not a BAD chip, it's more a good quality jack of all trades, rather than a master of two or three.
  11. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    Those are de-interlacing chipsets not mpeg decoders.
    There is more to choosing a partner for mpeg decoding than whether it has the "bug" or not. John Dawson has gone in to this on previous threads. A search of posts by him will no doubt bring them up.
    I would hope that future Arcam DVD players are bug free too though.
    Gordon
  12. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Are you going to be using player with a progressive screen? e.g. plasma or projector; because if you are using a regular CRT you won't see it anyway.
    I have DV88+'s more expensive cousin, the Arcam FMJ DV27 DVD player; which uses Zoran Vaddis 5 for MPEG decoding and an additional Silicon Image SiI504 chipset for delinterlacing (the DV88+ uses the Vaddis 5 for deinterlacing).
    Does this player, have the chroma-bug? Yes, but not as bad as many players.
    Have I noticed it? Of all the DVDs I've watched, and that's a lot, only ever seen it on Tron and Moulin Rouge.
    Does it detract from an otherwise excellent player? No.
    Chroma-bug on SkyDigital, now that's a different story.
    StooMonster
  13. camlogan
    camlogan
    hi there, I have a sim2 DMF which I project on a 5 foot screen so it will be visible - if I looked for it I guess.
    btw; do you ever not use progressive - i.e. the silicon chip?
    Now that progressive is on I use it always whether its better or not ;)
    CaM
  14. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
  15. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    Cam: Due to the way the sage de-interlacing chispet in the DMF works the chroma bug is masked so it will be a lot harder to see on your system.
    Gordon
  16. camlogan
    camlogan
    hi there, that article sure is an excellant read - thanks for the link.;)
    CaM
  17. camlogan
    camlogan
    hi there all - you have all been most helpful. I guess the problem with being a bit of a 'techy geek' is finding out that there is always at least 1 chipset out there that is better than the one you currently have...and then wanting it :D
    I'm very glad I got an arcam - not least because when I return to NZ I'll have something that was made in england as its all sony, denon or marantz down there.....
    I guess I'll also be upgrading it sometime when I can justify to myself that I need a better chipset along with dvd-audio...I sure am glad the arcam is upgradeable.
    thanks
    CaM
