Criterion ?
Discussion in 'Movie Forum' started by Zog, Jun 6, 2002.
  1. Zog
    Zog
    Aug 16, 2001
    429
    Manchester
    +5
    Are all their discs R1 ?
  2. European
    European
    ...no... quite a few of them are R0 (i.e. not region-coded)... of course all are NTSC ! ...
    . . . :eek: . . .
  3. Zog
    Zog
    Aug 16, 2001
    429
    Manchester
    +5
    how will I know if I can play an NTSC on my set-up.
    I currently use a PS2 into a Yammy amp using S-Video leads.
  4. tee
    tee
    Sep 17, 2000
    2,704
    71
    Close by
    +50
    I'm not sure about the PS2 but you also need to check your TV manual to see if that accepts NTSC - most newer TVs do but its worth checking first.
  5. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    A region 2 PS2 will output NTSC as 'pure' NTSC (colour freq. 3.58). It is quite 'happy' doing so via s-video connections.
  6. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    As has been said there are no probs with your amp or PS2, it is the tv that could be the problem - check the manual.
    You will need Region X to play region one DVDs on your PS2 and you will need a new Scart lead (I have the Blaze Ultimate Scart) to watch region one in rgb.
