Crimping cat5e - only solid colours!
Discussion in 'Cables & Switches' started by freddyq, Jul 28, 2012.
  1. freddyq
    freddyq
    Jul 26, 2011
    172
    +5
    Hi All,
    I'm sure this is a novice question so apologies in advance!
    I've purchased a cat5e cable and crimping kit but when I cut open the casing the wires inside are a) not twisted and b) only solid colours (Green, Brown, Blue, Orange and 4 whites). All the diagrams online show twisted wires where one is solid and one has a striped pattern so I'm confused now as to how what cable it is I have and how I crimp it!
    Can someone please help?
    TIA
  2. freddyq
    freddyq
    Jul 26, 2011
    172
    +5
    OK so it's not 4 whites its light blue, light green, white and purple
  3. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,305
    Poole
    +11,915
    Cat5e cable MUST contain twisted pairs or it won't work. Sometimes each pair is colour/white
    It may be that in stripping the insulation you straightened out the wires.
  4. ben2579
    ben2579
    Apr 13, 2005
    524
    +24
    I have had the same problem and suspect it is cheap cable. It was a 20m cable from amazon with two plugs fitted. I had to cut it to get it through the wall and then found the solid colours. Has anyone ever refitted a plug to one of these cables.
  5. freddyq
    freddyq
    Jul 26, 2011
    172
    +5
    I did manage to get it work after contacting the seller (I bought the cable from ebay). The colours I could see in the cable were:
    Red, Green, Brown, Blue and then 4 lighter coloured wires which were difficult to tell apart but were light blue, purple, light green and white.
    He suggested I use the following order:
    white
    light brown
    light green
    dark blue
    light blue
    dark green
    light brown (what I thought was purple)
    dark brown
    I followed that colour coding and it worked.
  6. ben2579
    ben2579
    Apr 13, 2005
    524
    +24
    I contacted the seller on amazon and suggested it was a fake and not to the cat5e standard and I got a full refund. Have now ordered some official cable. But might try and connect this one as well.
