cricket in hd
Discussion in 'Satellite TV, Sky TV & FreeSat' started by gerryman62, Dec 24, 2006.
  1. gerryman62
    gerryman62
    Feb 20, 2006
    709
    belfast
    +69
    hi just looking at the sky sports mag i see england v new zealand mon 15th jan 10.45pm live ss1 also hd,australia v new zealand sun 28th jan 4.30am live ss2 also hd can this be right, pages 37 and 40 if so great:clap:
  2. uno
    uno
    Mar 17, 2006
    657
    28
    +90
    No its just an upscaled version as far as I can see like they have doing for the Ashes
  3. gerryman62
    gerryman62
    Feb 20, 2006
    709
    belfast
    +69
    y put the also in hd tag there wen its not big let down:mad:
  4. samjpullen
    samjpullen
    Nov 24, 2004
    3,882
    Keighley, West Yorks
    +142
    If its got a HD tag then that normaly means it will be in HD :thumbsup:
  5. Mighty Gaz
    Mighty Gaz
    if it has HD on the tag, then it is HD.
  6. seaviewuk100
    seaviewuk100
    Wrong!
    The Ashes were tagged in error as HD.
    Just had a quick check on Digiguide and that doesn't have a HD tag for the first match mentioned in the opening post.
  7. samjpullen
    samjpullen
    Nov 24, 2004
    3,882
    +142
    I guess you should re-read what i said...
  8. Mighty Gaz
    Mighty Gaz
    sorry, i'll rephrase.
    if it has HD on the tag, then it is HD. excepting any errors which may be made by humans.
  9. mastermax
    mastermax
    Oct 25, 2006
    186
    how much is the upscaled version of the ashes better than on skysports 1. I've only seen it on SD channel an just wondered if there was a great or small difference compared???
  10. samjpullen
    samjpullen
    Nov 24, 2004
    3,882
    +142
    There isnt a major difference like HD but its better, mainly because of the higher bitrates, or so whats what i have been told...
  11. mastermax
    mastermax
    Oct 25, 2006
    186
    I've noticed that some sports programs on sksyportsHD1/2 are rightly in widescreen format but on the SD channels are reshaped to the horrible 4:3 ratio. how come programs are in widescreen ratio on HD channels and then changes for SD channels??????
