Crestron IR Codes and Yamaha Pronto Codes
Discussion in 'Smart Home, Climate Control & Security Forum' started by juschillin, May 4, 2005.
  1. juschillin
    juschillin
    I am here: http://www.yamaha.com/yec/customer/codes/ST_IR_DVD-S550.pdf
    And I need to use that Pronto code with Crestron. I try and put it into Deal via the .CCF function but it tells me there are not enough or to many characters. I really need these particular codes. Is there a way to convert the HEX or the DECIMAL into the IR format for crestron?
  2. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    juschillin,
    Have you tried to learn the code on your pronto and then take it across to Deal? The other places to look are www.remotecentral.com & the Crestron user group on the Yahoo.
    Hope that helps,
    Pemberto
