drpobgyn
Another old Crestron System. We also purchased a house with an existing home theater system. The audio side of things uses a Crestron Addagio AADS. Everything has been working fine until recently where we are noticing that the Left channel is significantly lower in volume than the right, This occurs across all sources and for all rooms. The original installer seems to think this amp has gone bad but they no longer service Crestron. I am wondering if the other forum members agree that this is a bad amp. Also, I wanted to know if it was possible to buy a used one on the net and swap the programming from the old one myself. Or at least have it down relatively inexpensively. If its going to be pricey then its probably time to scrap the whole thing and redo it all.
