Creative Zen xtra Repairs - HOW??
Discussion in 'Headphones, Earphones & Portable Music' started by roseda.y00, Feb 2, 2005.
  1. roseda.y00
    roseda.y00
    Im getting really stressed out about the fact i cant get my Creative Zen Xtra fixed. It has a faulty headphone socket and the charger input goes into the player whenevr i try to charge it, so it wont charge!!!!1 :mad: can anyone recommend anywhere near manchester where i can get it repaired for a reasonable price? This player means alot to me!! :(
  2. Ian182
    Ian182
    Oct 15, 2002
    885
    46
    Leeds, West Yorkshire.
    +100
    Is it still under warranty ?
    If so, you should be able to take it / send it back to where you bought it from.........
    Ian.
  3. Ian182
    Ian182
    Oct 15, 2002
    885
    46
    +100
  4. roseda.y00
    roseda.y00
    The problem is, i bought it off amazon, so i dont think it came with one, if it did, then the warranty lasts for 1 year thanks alot
