Creative Zen Touch 20gig Firmware Update
chrislad
Does anyone know of or have a link to a site that will update the firmware to remove the 'Europeans have sensitive hearing' bar on this player? Thanks in advance.
sirlukas
Established Member
Is there such a bar?
If yes, try to e-mail them.
chrislad
There is such a bar. All EU music equipment comes with an volume limiter, which basically means the highest volume isn't really the highest. An American iPod at full volume would be louder than a Euro one at full volume.
sirlukas
Established Member
I thought, that only Sony was obeying the rules ;)
chrislad
I'm pretty sure Apple do as well. My Zen is normally loud enough, but in the city centre, it's a strain to hear it.
S
shadowritten
Chrislad, go to www.creative.com. Select the American site (not the European site!), and go to Support section. Follow the links from there and you'll download and install the US, not the EU, firmware update.
Two things: you might have to wipe the existing firmware (can't recall now cos it's ages since I did mine) before loading the new - unless the FW number is more recent than the one already on your player. And make sure you've attached the AC adaptor and USB cable first.
Good luck!
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
