Creative Speaker Stand
Discussion in 'Home Cinema Speakers' started by phindme, Jul 14, 2004.
  1. phindme
    phindme
  2. Benedict
    Benedict
    Mar 10, 2003
    552
    Welton, East Yorkshire
    +20
    I think the only place you can get these from is Creative themselves.
    I've got three of these stands for my rear speakers and they're actually quite well made.
    The base plates are mass loaded and the columns are also built so you can run the cables down inside them and out through a hole in the bottom of the base.
    The columns themselves are made up of three tube sections which screw together, but you can't see the joins once they're screwed into place.
    Are they worth £20 each? Well if you want a neat and tidy way to mount your Creative speakers then I would say yes. (Bizarrely it's 10p cheaper to buy them individually than in pairs!)
