Creative soundworks
Discussion in 'Home Cinema Speakers' started by twoblacklines, Sep 10, 2007.
  1. twoblacklines
    twoblacklines
    As i bought these with pc's in the past, i have 10 of these "15wrms" satallite speakers.
    [​IMG]
    Now if i pair 5 or 10 of them with an onkyo reciever and a bk monolith DF, would it sound ok ?
    I cant afford a monolith and some bookshelf speakers and the reciever all in one go! :(
    so either
    reciever + crappy 5.1 speaker set
    reciever + CS satallites + bk monolith - upgrade speakers 4 months later.
    reciever + £400 bookshelf speakers - add sub later and 3 more speakers
    reciever + 4 speakers and centre - add sub later
    which would you choose ?
    I also have some integrated hifi speakers i could use temporarily....
    thanks
  2. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    If you're willing to spend.... but only issue is timing (of the spend!) then "option no. 3" .... otherwise "option no 4".
