Creative Muvo2 and running on mains......
Discussion in 'Headphones, Earphones & Portable Music' started by Ian Carter, May 31, 2005.
  1. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    If I run my Muvo2 on the mains the majority of the time, as I do, should I take the battery out?
    When I connect the power the battery normally charges for a couple of minutes then stops. The display then shows the power signal within the battery indicator. If I remove the battery the display changes to a 'power only' icon.
    Will I damage the battery buy giving it a constant feed?
    Cheers, Ian
