Creative MuVo Micro N200 (1gb)
Discussion in 'Headphones, Earphones & Portable Music' started by storming, Jan 1, 2005.
  1. storming
    storming
    Nov 20, 2004
    17
    Thinking of buying this player as it seems to have everything i want at a reasonable price (£130) but perhaps because it is a new model I have been unable to find a single consumer review.
    Has anyone got one or knows where i can find a review? Cheers.
  2. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    783
    London
    +19
  3. Tom_on_mars
    Tom_on_mars
    word up
    just got one of these and i love it. the only problem is that the player seems to put all the tracks in alphabetical order instead of the order they are in on the albums they come from. anyone know how i can rectify this?
    ta
    Thom
  4. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
  5. scouse
    scouse
    Jan 22, 2003
    273
    Balham
    +3
    If you're after a good flash player i can recommend the iaudio U2 1Gb flash player. I imported it from the us via http://www.suntecint.com/ for $264.99, which works out about £140. --which means no import duty :smashin: delivery in about 3 days as well
    The specs are here...
    http://eng.iaudio.com/
    I have a creative muvo 256Mb and the sound quality in my opinion gets blown out of the water by the iaudio
    It's also been made the cnets editors choice:
    http://reviews.cnet.com/JetAudio_iAudio_U2_1GB_Platinum_Black/4505-6490_7-31129769.html
    There is community of users that contribute to a forum on the website that gets read by the techies of the company and firmware updates are made on user recommendations and wants...
    just a suggestion. :thumbsup:
  6. RoobyRoo
    RoobyRoo
  7. ste_d73
    ste_d73
    Dec 13, 2004
    26
    I've not got a N200, but I do have a "V200" which is almost identical. Basically the N200 comes with a link lead and the "V200" doesn't. Instead it splits in 2 to reveal a USB connector, thus you don't need to carry a lead around with you 24/7.
    I am very pleased with mine. It is 1GB which is plenty for me and comes in white. Got mine from pixmania.co.uk and it came with a 2 year warranty. Total cost was £123.00 inc handling.
    With regard to the way this player stores tracks, it seems that using the provided software tracks are loaded alphabetically. However if you have an album in your "my Music" folder and you just open up windows explorer and simply drag it across to the removable drive(the mp3 player) this copy's exactly what it sees and maintains the track order.
    hope this helps! :hiya:
