Creative Mp3+ external sound card?
Discussion in 'Computer Components' started by zoolap, May 29, 2003.
  1. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +8
    Some of you may be aware of the Creative MP3+ external sound card (should I say adapter)
    I think there is a similar M-Audio device also.
    What I'm thinking is - in a htpc setup internal soundcards are open to inteference created from the m.board and other devices. Using an external sound card should in theory cut down on this. What about using a device like that above to pipe Dolby Digital/DTS via the SPDIF to my amp?
    Do you think it's worth doing or should I just get a conventional PCI sound card and use the SPDIF on there.
  2. thr5914
    thr5914
    hey man i think i might be able to help...
    just here recently i just hooked up and old reciever i bought for 50 $ to my onboard soundcard using a y splitter or something (its got one end with a 1/8'' and the other with the red/white audio cables).
    but when you do this you pick up that crazy interference(from what i read its mainly from the powersource in the computer).
    so i did some reading and came across some help. this one guy said to use a thing called a ground loop isolator, something that you can buy at radio shack for 15 bucks, and it comes with the y splitter thing. and man, it worked great, no interference at all now. here's the website that im talking about.
    http://www.epanorama.net/documents/groundloop/home_solving.html
    hopefully maybe that helped.
