Creative Audigy 2 to Denon 3802 Amp
Discussion in 'Desktop & Laptop Computers Forum' started by Walter Sobchak, Mar 10, 2006.
  1. Walter Sobchak
    Walter Sobchak
    Mar 29, 2005
    1,034
    +37
    What kind of cable do I need to buy?
    Ta
  2. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
    Hi,if analogue outputs are stereo(female) jack sockets you will need a cable/cables with male stereo jack to 2 RCA cables/connectors(need 3 of these for 5.1).If you want to send out the signal digitally you will need either a SPDIF optical lead or coax lead(see the very recent post to do with creative SC's & RAW digital signal for a bit of extra info thou),easiest (& less cables,expense etc) way to go IMO,but you cannot send DVD-A via this way(its to stop you coping :( )
    Cheers BOB
  3. Walter Sobchak
    Walter Sobchak
    Mar 29, 2005
    1,034
    +37
    Do you know where I get a 15M Coax lead from?
  4. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
    Hi,have a look in the Sub forum(used on Subs with there own Amps).You can get them that lenght,but if a quote you a cheapish one,i'll prob get some flak:) :) :)
    Cheers BOB
    ps A lot of the retailers advertising on this site will sell them(IMO i would not get into Mega Buck territory thou).Theres also a guy on these forums who sells them,not cheap cheap,but supposed to be good & well made.
  5. ccparkhill
    ccparkhill
    Oct 18, 2003
    509
    London, SE1
    +14
    If it's anything like my SB Live! 5.1 card you'll need one of these.
