Creating DVD's from Mini dv
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by sanj_4, Nov 1, 2004.
  1. sanj_4
    sanj_4
    Oct 6, 2004
    Hi There,
    I was wondering if any one has any tips on creating DVD's from Mini DV tapes?
    I have a sony dcr-pc105 and last night I tried to transfer my video's to dvd, but the quality was very poor when the DVD was played back? I did use a usb cable rather than firewire does this affect quality?
    I was using Movie maker and then converted it in Nero 6 to burn onto DVD not sure if the conversion drops quality?
    Any help/pointers would be appreciated regarding How to's for best quality reproduction onto DVD's.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,484
    Rainham Essex
    +2,487
    Well I can honestly say that you will never get good quality onto a DVD if capturing DV via USB, its just not up to the job. The only way to get full quality video onto the PC is via firewire.
    File conversion to MPEG-2 (this is the file that is used by a DVD) to be copied onto the DVD does result in a loss of some quality, but under normal circumstances this will be slight and mostly unnoticed. Movie Maker is fine for editing and Nero is a good program for burning a disk but you may find a dedicated authoring program makes life easier and you can add chapters and a menu that I don't think Nero will let you do.
    Mark.
  3. johnjackthom
    johnjackthom
    Sep 20, 2001
    759
    Northumberland
    +284
    Hi, THE most important thing is to use the firewire connector.
    USB is only useful for webcam or stills.
    If you don't have a 1394 connector on your PC you can get the one I'm using from dabs.com for around £12. This even includes a 6pin to 4pin firewire cable.
    ie Manufacturer : DABSVAL
    Product : Lucent Firewire 2/3 Port PCI
    Quicklinx : 179GZD
    Hope this helps :)
    Sorry Mark, you just beat me to it. :thumbsup:
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,484
    Rainham Essex
    +2,487
    Yeh, when you have 'waisted' as much time on the forums as me you'll be able to type a lot quicker too :devil:
    15 years working in IT and its the forums that teach me to type, now all I need to do is learn how to spell :blush:
    Mark.
  5. sanj_4
    sanj_4
    Oct 6, 2004
    Cheers for the help guys off to Dabs or Ebuyer for a Fire Wire card!
