Creating DVD-RAM Discs.
Discussion in 'Blu-ray & DVD Players & Recorders' started by simkna, Oct 4, 2004.
  1. simkna
    simkna
    Sep 9, 2004
    188
    Leicester
    +8
    I want to be able to create DVD-RAM video discs on my PC to play in my Panny E55, then reformat and use again once watched. I am struggling to find any software for the PC that will do this. I use DVD Author and Nero to create DVD-R discs from e55 recorded DVD-RAM, but am not having any luck with creating Panasonic readable DVD-RAM discs from PC. Any ideas?
    Si.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Have a look at the Ulead products ( www.ulead.com ) - several of their applications can create VR mode recordings for use on a DVD-RAM. Alternatively why not use DVD-RW? Although your Panasonic cannot write to them it will read them. Accordingly you could author your video clips in TMPG Enc and just burn to DVD-RW instead of -R. You can then re-use the disk.
  3. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    I would also recommend using DVD-RWs.
    They're so much cheaper than RAM discs and will play in most other DVD players.
    I'm using Datasafe discs, at 60p each, as the equivalent of cheap videotapes.
    These play back perfectly in my E60.
    Not sure I'd use those for archiving however. :)
  4. dude1971
    dude1971
    On the subject of DVD-Ram disks, how do you reformat them? I've tried it in my Panasonic e60 but it won't do it and reformatting ito on the PC using fat32 hasn't helped. What have I done wrong? All I did was copy a movie to it.
    Regards
    Dude
  5. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    I've formatted Memorex and Panasonic RAM discs on a PC in order to try them out for data storage (SLOW), but didn't have any problems reformatting them in the E60, so I don't think that's the problem.
    Were they good quality discs? :confused:
  6. dude1971
    dude1971
    It was a Smart Buy disk, the Panasonic ones are ok to be reformatted.
  7. dude1971
    dude1971
    Now the Panasonic one won't reformat either. If I try to burn to it on the PC it says it's full up but there are only a few files on there and they are tiny. I've erased it using Nero and now it think it's a CD. Help!
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Try reformatting it on your PC. Ensure you use the UDF2.0 option!
  9. dude1971
    dude1971
    I have tried it on the PC, what is UDF 2.0 - I'm not familair with that and I searched for it on google but I'm none the wiser!
    Regards
    Dude
  10. daydreamer
    daydreamer
    from google:
    What is The Universal Disc Format (UDF)?
    The Universal Disc Format (UDF) specification was first released by the Optical Storage Technology Association (OSTA) in 1995 and is designed to be a common logical file system for all removable optical storage media. Over the years various updates to UDF have been introduced to add new capabilities. So with DVD, UDF 1.02 is the standard file system used for DVD-Video, DVD-Audio and DVD-ROM prerecorded and writable discs. UDF 1.5 is frequently employed for incremental writing while UDF 2.0 applies to DVD-RW and DVD-RAM discs written in the DVD Video Recording (DVD-VR) format.
    http://www.osta.org/technology/dvdqa/dvdqa2.htm
  11. dude1971
    dude1971
    OK, that makes sense but if I'm just reformatting the disk how do I know what version of UDF I am using? I think I formatted it using fat32 and I've also tried using Nero to no avail.
  12. sweat100
    sweat100
    I suggest you install the Panasonic dvd ram driver, i once format to FAT32 and can change to UDF2.0 No problems. It supports drag and drop also.
    It is very user friendly
    and is very good esp when u are using Panny standalone recorders.
  13. dude1971
    dude1971
    Hi Sweat
    I had a look on the Panasonic website but it seems to refer to Panasonic drives, I've got an LG device in my PC. Does anyone have the link for the drivers so I can reformat my DVD-Ram disks?
    Regards
    Dude
  14. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Agree with Sweet100's advice - get the Panasonic DVD-RAM Format utility and your life will be somewhat easier. Have a look and see if you can find it - if not PM/e-mail/ask again on Saturday and I will link you to it (I am on GRPS at present and am not about to make Vodafone rich by searching for it).
  15. dude1971
    dude1971
    OK, I searched for Panasonic DVD-RAM Format utility and it still seems to refer to Panasonic drives in the PC. I read a few posts on newsgroups and there were a few people with XP that could only get their DVD-Ram drives to use UDF 1.5 and not 2.0 - I don't want to download the drivers if they are the wrong ones. It took me a few days to get the correct ones from the LG website!
    Regards
    the Dude
    p.s. There's no rush Raszcak, please don't get a huge phone bill on my behalf mate unless it's a company mobile and you don't pay the bill :-o
  16. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Roger - I'll post a link on Saturday (if I haven't posted by Saturday evening just post again to remind me - I have quite alot on between now and then and am bound to forget).
  17. dude1971
    dude1971
    It's baffling me now. The format of the dvd-ram disc is UDF, according to the PC, but it has no space left. But there's only 4kb of files on there. However, it says I have 4.7gb free on my e50?
    Regards
    Dude
  18. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    I did forget! Here's the link to the DVD-RAM Format ultility:
    http://panasonic.co.jp/mke/support/dvdram/lim/eoem/downxp.html
    The software your interested in is the DVDForm ultility which makes formatting a DVD-RAM simple. Try this programme and hopefully it will solve your problems.
    Do you have InCD running BTW? It can cause all sorts of problems in my experience.
  19. dude1971
    dude1971
    Cheers guys, I'll try this and see what happens.
    Regards
    Dude
