Creating a CDV
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by newtoallthis, Dec 16, 2004.
  1. newtoallthis
    newtoallthis
    Hi all.
    I have created my first short movie using Windows MM2.
    This may seem a naive question, but how do I create a CDV that I can then play in a DVD player?
    Can't seem to find any relevant help in the software, so any assistance would be gratefully received.
    Regards
    Paul
  2. Brian110507
    Brian110507
    Don't know what a CDV is.
    If you want to make a VCD (Video CD) or SVCD (Super Video CD) or better still a DVD to play in a DVD player you will need another editing package. The VCD created by MovieMaker cannot be played on a DVD player only in a computer. Have a look at editing programmes from Ulead or Pinnacle among many others all of which produce VCD's , SVCD's and DVD's which *should* play on your DVD player to your TV.
  3. laser
    laser
    Aug 1, 2004
    986
    Hartlepool
    +45
    You could also try Nero 6 to create a VCD, SVCD or DVD. You could download a trial version to test it out. It's also worth having Nero Vission Express 3 whch can do marvellous things with video files and converting them to correct format for DVD.
    www.nero.com
  4. newtoallthis
    newtoallthis
    Yep, VCD it should have been :blush:
    So if I understand correctly I can't actually create the VCD from the MM2 file, I've got to convert it into another format first?
    Paul
  5. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,039
    +154
    Just FYI, a CDV is a 5" analog video disc which holds about 4 mins of video - Only playable in laserdisc/CDV players.
    What format is the MM2 file?
  6. newtoallthis
    newtoallthis
    Hi Figrin_Dan,
    It is currently saved as .WMV. Does this make a difference?
    Paul
  7. Brian110507
    Brian110507
    Yes - that is just above the very lowest quality video you can get.
    If you are capturing from a DV camera you should capture - edit - and save as .avi to preserve your quality. and only convert the final video to an appropriate format when you are ready to burn a disc. Most programmes should be able to accept an .avi and change it as necessary when you tell it what sort of disc you want to burn. Failing that if you have already captured as mpeg then you need mpeg-1 Not mpeg-2 for a VCD.
  8. Centurion
    Centurion
    If you are going to make a vcd or svcd be sure to know you will be dissapointed with the end product. These formats go through alot of compression (meaning low picture quality) so that they will fit on a cd. If you have the money buy a dvd writer and save yourself all the hassle.
