Create DVD from MPEG
Discussion in 'Desktop & Laptop Computers Forum' started by HMHB, Sep 2, 2003.
  1. HMHB
    HMHB
    Nov 11, 2001
    26,653
    Nottinghamshire
    +5,372
    Has anyone found any decent software to create DVDs from mpg or avi files ? I've tried a couple so far (Sonic MyDVD and NeroVision Express) and failed with both.
    What I need is something easy to use as I don't want to be messing about for hours.
  2. Kramer
    Kramer
    Was browsing DVDr-help earlier, came across a few apps for just that.
    Have a peek here:
    www.dvdrhelp.com
    :smoke:
  3. HMHB
    HMHB
    Nov 11, 2001
    26,653
    Nottinghamshire
    +5,372
    OK - ta.
  4. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    I have tried a number of apps, and for ease of use I like Ulead DVD Workshop. I have version 1.3, but I believe they are now on v. 2.0.
    You can use AVI,MPEG1 MPEG2 and other sources, create DVD, VCD and SVCD, all with menus, and burn direct from the program.
    If you use Nebula files they have to be corrected with PVAstrumento first, then can be compiled to a DVD without re-encoding
  5. HMHB
    HMHB
    Nov 11, 2001
    26,653
    Nottinghamshire
    +5,372
    I think I need to do a bit of reasearch - Nebula files is something new to me !
    I'll have a look on the DVD workshop web site and see what they are offering
  6. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Sorry for any confusion.
    A lot of users here have the Nebula DigiTV card, which produces MPEG2 files direct from the RF input on Freeview channels. These have to be corrected before they can be used in DVD authoring programs. (UK only)
  7. HMHB
    HMHB
    Nov 11, 2001
    26,653
    Nottinghamshire
    +5,372
    Aha - thanks I was begining to think that it was going to be more trouble than it's worth !
  8. Adder_Lee
    Adder_Lee
    i have also used Neo dvd standard4, it takes approx 2hours to convert from mpeg to dvd, but found that the quality is good, my playbacks are often jumpy. but have not found anything that beats it..
  9. Steve1138
    Steve1138
    you could look at a new one called DVDLab
    Had a "quick play" and it looked OK.
