creased screen
Discussion in 'Projectors, Screens & Video Processors' started by HAL 2007, Apr 26, 2007.
  1. HAL 2007
    HAL 2007
    Apr 26, 2007
    Hi I have just unpacked all my av gear and set up my cinema room. And I find that my screen has a few creases in it. Any idea’s as to how I can get rid of them
    The screen is a fixed screen so it is under tension always
    T.I.A
  2. Otto
    Otto
    Jun 19, 2003
    322
    28
    +61
    If it's a fixed screen and it's already assembled, give it a few days. Normally, the tension should take care of the wrinkles over the course of a few days.
    If they don't dissappear after a week, use a hair dryer at the spot with the wrinkles. When you warm the fabric, it becomes more elastic, removing the wrinkles. Make sure not to hold the dryer to close, as you need to warm it abit (not melt it).
    Good luck,
    Otto
    Beamax
  3. HAL 2007
    HAL 2007
    Apr 26, 2007
    Thanks m8 will try that.
    Just one small proplem I shave my head ever three or four days so doint have much use for a hair dryer, will have to borrow one :)
  4. Otto
    Otto
    Jun 19, 2003
    322
    28
    +61
    Get ready for a new experience then :D
    Good luck!
    Otto
