Crazy seating idea!!
nathsea
Hi all,
Getting on with my dedicated room and starting to think about seating.
At this time we can`t really afford nice recliner seats etc. So I thought how about building a large bench seat about 8` wide by 4` deep, covering it with foam and the loads of cushions, almost like a large pit!! so as we can either lay or sit or do whatever :devil: !!
Then underneath I thought I could have my equipment rack , this will free up space at the front end of the room (as we dont have the largest space available) it will also allow easy access to the controllers for the consoles / keyboard etc?
All comments appreciated - am I utterley stupid and should go and buy some seats from Ikea? or do you think it will work?
Many thanks in advance
Nathan
E
Exeter Man
Sounds good to me Nathan. Amp underneath should provide a nice bit of heat too :smashin:
Regards
F
fufna
Regards
Indeed, depending on what you use for amplification, it might well be too much heat (especially in the summer months)
I know my amps run very, very hot.
nathsea
thanks for the replies,
I thought that i could vent the shelves underneath to the rear as they go to the utility room. Would this cut down on the heat?
Also has anybody used foam for this sort of thing before is it actually comfy or would I have to perhaps look for some sort of filling and make a cover to hold it in (like a bean bag but full of something else!) :p
keep the suggestions coming - many thanks
Nathan
F
fufna
The trouble with heat, is that it rises!
regardless ofhow many vents you put in, it will still get hot (that is of course only if your equipment runs hot)
Foam would be much easier to work with and you can buy it online in a miltitude of thinknesses and grades cut to sze for the exact dimensions you require.
This foam is actually the stuff used in making sofas/armchairs and the like, so it really wouldn't be that far removed from the quality of a regular sofa if you built it properly.
buns
also your movement on the seat could cause your dvd player to move and give you minor playback issues
ad
nathsea
ahh.... good thinking, how about if i put some fans in to draw the heat away , would this work ? I suppose it would but it will be quite noisey!!
F
fufna
If you went for 80mm silent fans you wouldn't hear much at all.
just make sure you fit them the right way round;)
It will still get bloody warm though!!
R
rob_w
I missed this post - some input for you..
A futon mattress would be about the right size ? - maybe with some large cushions at the edges.
The fan ideas are good - maybe line the bottom of the seat with silver foil to insulate. - If you think heat would be a problem.
If your worried about the dvd skipping etc, then build a seat first, with a couple of gaps beneath that you can slide a standalone rack or two into - then the racks are isolated from the seat...
Think about adding a couple off bass shakers to the seat for when your doing 'whatever':devil: :D
Good luck with the project - post piccies!
Rob
Similar threads
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
