Crayons out! The best way to connect this system?
Discussion in 'Plasma TVs Forum' started by Planet__, Sep 22, 2003.
  1. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    I don't get my kit for a wee while, so I've been thinking how to connect it all by reading this forum and the online manuals. This is what I have come up with so far. Pictures tell a 1000 words...
    Here's System 1:
    [​IMG]
    Here's System 2:
    [​IMG]
    Comments on what's better, anything I've missed etc
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Well I'm going to do a Blair and recommend the third way.
    Sky into JS YUV convertor into plasma
    PS-2 and DVD into av amp.
    That way you can have tv pinp with all setups, its possible that you might want to watch the footie in a small screen whilst playing a game or watching a dvd waiting for a tv program to start. Unlikely that you will need dvd and ps-2 at the same time.
    I have the TV PinP alot esp when champions league is on.
    Neil.
  3. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    Thanks for that Neil, or is it Tony? :D
    I do agree that Sky should be PinP'd with the other sources, so that's going to go directly to the plasma - either VGA or component, just need to test it to see what's better. Is there even going to be a difference?
    After looking at the JS website I see they do a RGB to VGA converter, which is doing exactly the same as the syncblaster. So a fourth way! :D
  4. jont
    jont
    Apr 8, 2002
    4,251
    near Aylesbury
    +550
    Most people have gone down the syncblaster route only at some time to buy a JS unit anyway so I'd plump straight for that ...
    an advantage of setup 2 is that you don't have to worry about lipsync on the PS2 by splitting the audio/video ...
    Jon
  5. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    No I doubt there will be any difference. The JS units they are all of excellent quality and I would recommend these to anyone. So either component or VGA yoiu can't go wrong.
    Regards,
    Neil.
  6. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    BTW, what software are you using to do your funky pictures?
    Neil.
  7. PlasmaLover
    PlasmaLover
    Fantastic picture :)
    Please can someone explain what a JS YUV is, what it doesn, and where I can get one from?
    Sounds like a good option!
  8. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    www.js-technology.com
    John makes 3 excellent conversion products
    RGBtoSvideo, converts RGB signal to Svideo
    Plasma VGA, converts RGB signal to a VGA signal for a plasma
    RGB to YUV, converts RGB signal to a component YUV signal.
    I've had the top two and they are excellent products.
    Regards,
    Neil.
  9. GreenBhoy
    GreenBhoy
    Jul 30, 2003
    439
    Swindon
    +10
    Neil
    How did you connect your Dreamcast to your PW6? I am pretty pleased with RGB scart, but is there a better way? (VGA cable?)
    Regards GreenBhoy
  10. Timmy B
    Timmy B
    You can buy the DC VGA lead which outputs progressive scan 640x480 and is regarded as the best connection for the DC.
  11. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    I'd guess he used an illustration program like Xara X, Corel DRAW or Adobe Illustrator. Xara X does nice bevels and smooth gradients like those on the "Setup" title :)
    Can anyone tell I'm bored at work? :D
  12. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    VGA box for DC. I've got one you can have for a tenner.
    Neil.
  13. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Haven't got two have you Neil :devil:
  14. GreenBhoy
    GreenBhoy
    Jul 30, 2003
    439
    Swindon
    +10
    Neil
    Done m8, send me an email or PM and we will get it sorted....I work in London, so I can pick it up if its close...
    Regards Greenbhoy
  15. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    Cheers for all the comments lads!
    I'm going to go with the suggestion from Neil, and put the Sky to a converter and then into component - I'm updating the drawing at the moment (using Macromedia Fireworks MX Neil :smashin: ). I'll post it later.
    I just hope setting it up and all that is easier than drawing a picture!
  16. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    I do but I've sold one and need to keep one. Scan ebay thats where I got mine. Its well worth the cash.
    GreenBhoy PM'ed.
    Neil.
  17. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    cheers Neil, I know it was cheeky.
    John
  18. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    NP mate :) but seriously the dreamcast looks way ahead of the competition when you hook up via VGA. Soul Calibur looks better on the DC than it does on the Xbox, PS-2 and Gamecube.
    Neil.
  19. GreenBhoy
    GreenBhoy
    Jul 30, 2003
    439
    Swindon
    +10
    Neil
    PM'd re Thursday....
    Regards GreenBhoy
