crative zen touch to car stereo, best connection?????
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by andicapped, Sep 18, 2007.
  1. andicapped
    andicapped
    Jun 7, 2006
    1,668
    manchester
    +74
    looking for the best way to connect up my girlfriends creative zen touch to her Clio standard stereo. i may change the stereo to a USB compatible one but i dont think the creative mp3 player allows soind via usb, i could be wrong so correct me if i am.
    the next option is to get an FM transmitter. but which one? i had one of these on my ipod and it was crap. i'm sure they are better these days as i had mine agesand ages ago.
    can anyone advise me on what to do? or buy. thanks in adance
    andy
  2. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    You could just get one with a front AUX input. Then you have a lead running from the Creative's headphone socket to the input. Will work with any MP3 player then.
    HTH. :thumbsup:
  3. andicapped
    andicapped
    Jun 7, 2006
    1,668
    manchester
    +74
    that was my other option but i was told that it is not good to do that, dunno why.
  4. geomuss
    geomuss
    Jul 10, 2006
    2,041
    musselburgh
    +158
    had a stereo with the aux input, dont know if it wad just mine but had to crank the volume way way up even to hear it at a half decent volume (ipod 30gb video).
    tried with various other players and it was the same
    mine was an aldi special
    what about a decent FM transmitter?
  5. Sonic67
    Sonic67
    Sep 14, 2006
    46,362
    12
    167
    Home
    +25,391
    Bear in mind if you are transmitting via FM then you will only have FM sound quality.
  6. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    I had a Pioneer DEH-3900MP connected to an ipod via a 3.5mm lead and it worked fine. No volume issues and sound quality was good.
  7. andicapped
    andicapped
    Jun 7, 2006
    1,668
    manchester
    +74
    i'll give the aux cable a try and see how it sounds
    what about a digital transmitter? would i need a digital stereo?
