chemical man
- Joined
- Nov 20, 2005
- Messages
- 125
- Reaction score
- 2
- Points
- 47
What a crap day,
In October last year,my friend and i bought a panasonic DVD recorder 250gb
from richer sounds in Nottingham,when getting it home we found it was faulty. No problem, we rang them up and an exchange was ordered they did not have another in stock. Any way to shorten the story the replacement panasonic DVD recorder tuner has now died, so back to the shop and spoke to a real nice guy Bob, sorry i will replace it, but i only have an LG 500GB which you can have for the same money, fair enough, took it home set it up and guess what? that ones faulty. When its connected to the panasonic telly,
i keep getting signal break up on the television picture with message no signal. To see if this was a problem with only the television, I plugged the aerial direct into the television bypassing the DVD recorder without a problem.
So whats going on with richer sounds is it just bad luck? or are they graded Grey imports?
