Crackling speech on centre FS2
Discussion in 'Home Cinema Speakers' started by gedclink, Aug 23, 2002.
  1. gedclink
    gedclink
    The speech from the centre FS2 appears to crackle during advert breaks on channels..The actual program is fine but certain cable channels e.g UK food and others appear to be more problematic than others?
    No issue during broadcast but when the announcer comes on to present the next program, lots of static/ crackling with her words.
    Any ideas?
    Ged
  2. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    check the end caps and stand.
    one of mine vibrated at first and I traced it to that.
    only seemed to happen on particular things.. bass I think.. so an announcer's voice is a possibility.
