cracked disc- what to do?
Discussion in 'Movie Forum' started by cuewoz1, Jan 12, 2004.
  1. cuewoz1
    cuewoz1
    Oct 30, 2003
    187
    hi
    my blade 2 has 2 small cracks in the inner clear part of the disc.
    It plays ok, but I have been told it is dangerous as it could break inside the dvd player and bits come flying out.
    What could I do to repair the damage?
  2. Donnacha
    Donnacha
    Jul 4, 2002
    8,067
    York
    +4,208
    strange - mine too!! Is your's the Canadian R1 version?
  3. cuewoz1
    cuewoz1
    Oct 30, 2003
    187
    yes it is??
    :confused:
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Exactly the same here . I don't worry about it.
  5. nwgarratt
    nwgarratt
    May 5, 2002
    27,190
    +3,038
    My Blade Canadian R1 cracked ages ago. Is it the disc on the tray?
    Luckily I swap the discs around on my double amarays, so the film is at the back. It was the extra discs that cracked on the tray.
  6. pete18
    pete18
    Apr 14, 2002
    1,084
    41
    Torquay
    +3
    mine cracked as well
    :confused:
    from pete
  7. AndyL
    AndyL
    Got Blade 2 (Canadian R1) when first came out from Play, despite having the disc around 2 months before it began to crack in the middle, they replaced it for me when calling - no quibbles. Then that one had to go back, too, as it began breaking in the middle as soon as I put it back in the case. When calling they mentioned there was a bad batch that had suffered this, but hopefully that one would be the last.
    Have since put the disc inside a CD sleeve and just lodged where the chapter booklet goes. I noticed that some of the case second holders don't give at all, hence, think the problem.
  8. nwgarratt
    nwgarratt
    May 5, 2002
    27,190
    +3,038
    I got mine from Play as well when it first came out. They weren't interested in the problem. As the extras disc is the one that is cracked, I just replaced the case.
    For anyone whose film disc is cracked, is your extras disc fine? I think it was just the tray at fault.
  9. cuewoz1
    cuewoz1
    Oct 30, 2003
    187
    yes extras disc is ok.
    I just wondered if i should put any glue on it to stop the crack getting any worse.
    The case on this film is hard to get the disc out on the middle flap thing.
  10. nwgarratt
    nwgarratt
    May 5, 2002
    27,190
    +3,038
    My cracked disc has one single crack that goes straight through into the data area.
    I dealt glue would solve the problem It might come off inside the player.
    Cracked discs just get worse unless the case it changed. I had to send my star trek DS9 discs back as the packaging cracked the discs. They went from small cracks to the disc actually falling apart.
  11. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,155
    +688
    Mine's cracked too!
  12. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Just checked mine and its cracked to :( I'll put it in a plastic sleeve to stop it getting any worse. I'm also going to check the rest of my collection as i bet theres a few more like it.
  13. nwgarratt
    nwgarratt
    May 5, 2002
    27,190
    +3,038
    If you have Star Trek TNG or DS9, check those first. I had five seasons of cracked discs (two TNG and first three of DS9).
    DS9 cracked disc
  14. Korben Dallas
    Korben Dallas
    My reg 1 is also cracked .
