andrewt9763
- Joined
- Jul 9, 2006
- Messages
- 4,087
- Reaction score
- 927
- Points
- 824
Just after some opinions if a toilet under two years old and used normally should suddenly crack ?.
It’s appeared just under where the plastic seat front edge would touch it if the rubber feet were missing,in my opinion there is never much weight transfer through this as you sit on both side edges,the company that supplied it said it’s through use,there are only two adults here.
They have refused to even look at or accept pictures of the damage and said they would do a small discount off another new one.
